Re: Grease?
I don't know of any other grease fittings other than those, but you should grease the U-Joint and Gimble bearing at least once a year. I do it at the beginning of every season. Pull the outdrive and grease both fittings. I know the Gimble fitting is on the outside of the housing, but you really should grease that with the outdrive off. Otherwise, you are just squirting grease out of the bearing in one spot and no way to clean off the excess. Better to reach in there and turn the bearing while greasing and then wipe all the excess off so its not sitting in there.
