Recently purchased a Riviera 33 ft 2005. I am having trouble getting the gray water pump to run. At first was sluggish, then did not run at all. Can not locate a fuse relay switch. Tried replacing pump but it would not work when installed either. Where is that darn fuse to check?Thanks for you help.
