Re: GPSMAP 76
Well, how to explain this. How about the simple way.<br /><br />It sounds like someone, presumably the previous owner, loaded his own maps into the machine. The machine has a limited memory and part of it is devoted to what they call the base map. When you loade in other area maps from one of the MapSource disks (Blue Charts are a subset of the Map Source system) it deletes your basemap first. So then when the person sold it to you they probably went ahead and deleted the area maps they had loaded in. Because the base map was automatically delted by the machine and apparently the additional maps were deleted by the previous owner that left you with no maps at all. That sucks.<br /><br />Well, its not so bad. Just got the the Garmin site and click on Marine Products and then, if I remember where its located correctly, just go to the GPSMap-76 information page and it will have a link to allow you to download the Base Map, which you can then load back into your machine using the data transfer cable that should have come with the GPS. Also, as long as you are going to be in the downloading business, take a look at the version number of the software in your hand held. If its not up to date go ahead and download the latest version while you're at the Garmin site and load that into your GPS too. Of course you could go ahead and buy whatever set of the Map Source stuff you wanted if you want any detail worth mentioning on your machine. If its street maps you want get the USA Roads and Recreation set, it has every Interstate, major road, minor road, dirt road, lane, and alley in the country on it. Very handy.<br /><br />Thom
