GPS and TV antenne
LuckyPenny
OK, so I am going to ask two seperate questions at once.<br /><br />1. I want to install a Marine TV antenne (flat round0 on a short mast. I also have other things on the top of the house such as masthead light and a chrome searchlight. Will those items interfer with the antenne's ability to receive a clear signal?<br /><br />2. I have been looking at getting a USB GPS and wondering if there is a problem using them with MapTech products? <br /><br />Thanks
tommays
Re: GPS and TV antenne
1. i have no idea<br /><br />2.Most non marine stuff has a pretty short life on a boat :( even the marine stuff does soemtimes :) <br /><br />tommays
Rock Hall
I believe that if the software will accept an NMEA 2.0 data signal, it should work fine. I have an inexpensive USB GPS rcvr and use it with MS Streets and Trips. Works fine.
Rock Hall
On your first question. To be safe, locate the antenna as far from the other fixtures as possible. I think if you can get 6 ft away, it should be ok. Generally, you want to stay at least 1/2 wave from other objects. The lowest frequency that VHF TV uses is about 50MHZ. Thats about 4'. so 6 will be safe. Also, if possible mount TV on a different plane (higher or Lower) than the other objects. The higher the antenna is, the better it will work.
