Got the Mercruiser running! Bennett TABS ROCK!!
HT32BSX115
[FONT=Verdana, Helvetica, sans-serif] Howdy all,
This is not a rant....well maybe it is.....a good rant!
I cannot believe the support I received from Bennett on my Tab system.
My brother bought this 87 Liberator I have new.
A year or 2 later he had a Bennett Sport tab system with double actuators installed. It worked fine for many years.
As some of you know I got the boat a couple of years ago and removed the OMC King Cobra engine & Stern Drive and replaced it with a 97 Mercruiser 454 Bravo III drive.
I did all of this completely by myself.....AND this is the first time I have ever R&R'd a complete stern drive/engine!
I also did a bunch of fiberglass work in the engine compartment and repainted the whole inside to clean it up.
When I reinstalled the Tabs, I re-plumbed everything in copper and hooked it all back up to try it out.
The pump spewed hydraulic fluid all over!
Ok...Well the pump is almost 20 years old....I'll rebuild it! I removed the front plate on the pump and there's 3 O-rings there.
I called Bennett Support and asked If I could rebuild the pump with a new faceplate and O-rings.
The Tech Support person said he would rather we don't try to rebuild the pump. It should be replaced.
Then he said what's your address? I gave it to him.. He said please send the old pump back, there's no charge.
W H A T ?? NO CHARGE???
People. This sort of customer service and support is RARE!
Bennett Rocks!!
Oh, by the way......The boat launches like a rocket and tops out at 55 mph @ 4600 rpm in light lake chop, full fuel, 3 people onboard!
[/FONT]
Limited-Time
Re: Got the Mercruiser running! Bennett TABS ROCK!!
Glad to see all your hard work payed off :):). May she serve you well.
hullofalottatrouble
along these lines.. you can go to
thehulltruth.com
Bennett has a forum there.. its called Tabmans forum or something like that. Tom from Bennett Marine monitors the forum and will address all your issues there even if you dont have Bennett tabs..
They also swapped out my pump for free!! also offered to send me some free hyrdaulic lines.
I couldn't believe it myself.
HT32BSX115
Yes! Tom was the guy I talked to.
I am amazed that they treat me, with a 20 year old system, just a new customer that just bought a new one!
With that kind of customer support you cannot go wrong with the Bennetts.
farmboy
So what, their customer service rocks. The best thing is their product works. If I had a boat without trim adjustment, my first call would be to Bennett to find the proper fit.
jspringator
Thats what I have on my Bayliner (89). Always works.
