Got a Carb related issue I could use some advice
atomb
My Carb is sitting too close to the exhaust manifold and the throttle linkage i believe will not go into its idle postion (startup position) I turned her on twice and she was revving way too high i immediatly turned the engine off and I realized that this was the problem.
what kind a plate/ riser can iuse to bring the carb to sit a little higher? The carb is rochester 2 jet its not oem. Thanks for any suggestions.. I ran her last year with 2 gaskets and that seemed to work but im thinking there might be a better or right way to fix this issue.
atomb
Update SOLVED Re: Got a Carb related issue I could use some advice
Just found it official term seems to be "spacer"
fat fanny
tomb is that your stack carb? and if so does it do it with the linkage disconnected?
atomb
the linkage is disconnected and its not a stock carb.... last year i used two gaskets to raise the linkage so it cleared the exhaust mani. Does anyone know if they make thicker gaskets than the oem ones that come with the manifolds ?
thanks for the link fatfanny. the smallest is a 1/2 inch pus two gaskets that is much more height than i think i need.
fat fanny
For what it's worth you could just buy a roll of gasket material and make as many as you need just trace it out and cut or get a thin pc of aluminum plate and do the same (jig saw and file) Good luck
Kainon
Yes they do make a thicker gasket, and if you are not able to search for it here, I saw many posts listed on the Marineengine.com forum. ( very common problem )
ENSIGN
I've had a similar problem on a 3.0 where the bottom of the linkage on the carb scrapped the manifold.I just removed the lever and ground it down for clearance.
atomb
Thanks guys --I like the grinding it down idea ensign thanks. ill check the other forum as well.
atomb
is it bad to use 3 gaskets to get the height i need.?
PitchFork
I am using a Fel-Pro 1/4" gasket that I switched to in trying to elminate hard warm starts which did not fix the warm start issue as I have learning there isn't really a fix for it. Other than that I had no ill effects switching from OEM 1/16" gasket to 1/4".
atomb
thanks for the info pitchfork
atomb
I located the thick gasket and ill post a pic . It all worked at well. Thanks to all that gave a beep. Gotta rechage the camera batteries.
atomb
as promised check out this nice thick gasket:D
Thanks guys.......Thanks Iboats
