chrislee85
- Jul 20, 2008
- 20
I have recently acquired a Goodyear 025-3564 outboard. I was told it was a 5 HP and it appears by searching for forum that this model # is a 5hp. I am having a couple of problems though that would like some feedback on.
1. Re: the sliding speed control. Where should this be when I am starting the motor? I have no decals or stickers left.
2. When the speed control is all the way to the right (which I believe is fast) the engine backfires occassionally when I start it. Nonetheless, I can't get it to start. I try for about 10 pulls and then finally get the backfire. It will turnover some, but won't level out and run on its own. I assume the carb needs to be cleaned, but wanted to hold off as long as I could on that so I don't get gas all over the place. (Is there anyway to remove the carb without all of the gas running out of the tank?)
Thanks,
Chris
Thanks,
Chris
