Good idea, bad idea? Plan to get under a low bridge....
UncleWillie
Re: Good idea, bad idea? Plan to get under a low bridge....
Reality Check.
A small, 100 Gal, 800#, Water Sack with a 500 gph pump is realistically, going to take 20 minutes to fill and another 20 minutes to empty.
Add Setup and Storage and you are looking at an hour to get under the bridge.
Super duty the setup and maybe 30-45 minutes. Is this acceptable?
Another method is to Go Faster, The boat will squat in the trough behind the Bow Wave and sit lower in the water.
(1:30 in the Video)
This could be really scary the first time you try it.
As you approach the bridge, place your eye level exactly at the top of the windshield,
if you can NOT see the horizon in the distance you will NOT clear the bridge.
agallant80
(1:30 in the Video)
I think this may be one of those "but someone on the internet said it would work" type things. Not sure if I thought about it if I could come up with a worse idea than that.
Knot Waiting
Reality Check.
(1:30 in the Video)
I think this last part is meant to be tongue in cheek considering UncleWillie usually gives pretty sound advice. DO NOT approach this bridge at any speed. You'll wreck you boat and possibly injure yourself and crew or worse. Not to mention most bridges (especially low ones) are slow no wake.
Jonnybbad
I need to party with unclewilly! Your one crazy dude!
agallant80
While drinking Uncle Willy's pure mash liquor. Or was that uncle jemima's pure mash liquor....
RogersJetboat454
R
(1:30 in the Video)
Few tips if you try this;
-Wear a hard hat, or better yet a full faced helmet.
-Duck!
-When you clean the windshield off the boat, post a new thread asking about the best ways to avoid June Bugs. Willie may be able to drum up more videos of how cruise ships with displacement hulls do it.... :D
colbyt
Master Chief Petty Officer
While I would love to film many of the suggestions being implemented, the only one that makes any sense at all is hinging the windshield. I recently saw a how to thread where the guy had built and hinged one for his bass boat. I don't think that was here.
striker1211
Sorry for the lack of info, I've updated my sig. It is a 1996 Sea Ray Bow Rider 175 OB w/ Mercury 115hp. I'll have to look into piano hinges. Thanks.
delbellboy
I have used a twin size air mattress that you get at wally world to fill with water when I need more weight in my truck bed. It is more durable than you would think. never leaked yet. put as much weight as you need with minimum water movement.
UncleWillie
Before we discount the Go Faster Option completely, and I freely admit it sound ludicrous on the surface, there may be something to be said for it.
If you are not at planing speeds, you are a displacement boat.
The water in the Bow Wave and in the Wake came from somewhere, and some of it came from the hole you are riding in.
Getting on plane is often characterized as trying to climb out of the hole.
If the bridge is in a No Wake zone, this option may be moot. :grumpy:
I am not suggesting blasting through at 30 mph! :faint2:
However speeding up to the 8-12 mph range may produce your largest wake and lower the boat a few inches.
I can see maybe 6 inches as within reason.
All that said, I sure would never just go for it cold Turkey. :eek:
I need to party with Uncle Willy! You're one crazy dude!
Yes! I am crazy, But I am not Stupid!
The geek in me wants to set up a couple of Limbo Poles in a shallow lake with a piece of string set right at the Windshield Height.
Multiple passes at various speeds would demonstrate if the theory is sound.
Sometimes the crazy people are not as crazy as they appear. :D
Chris_94_Sprint_TX
The geek in me wants to set up a couple of Limbo Poles in a shallow lake with a piece of string set right at the Windshield Height. Multiple passes at various speeds would demonstrate if the theory is sound.
If I was closer I'd definitely help with these tests, sounds interesting and fun.
Chris
Fed
Do lakes have tides?
Maybe you could go under when all the water is up one end?
Salt water boater here.
littlerayray
the great lakes have small tides but most do not
Alwhite00
Just put more beer in the cooler.
LK
rbh
How about a picture of this bridge, maybe we can work this from a different angle.
lumpy1976
Small boat. Just have your passengers in the front, reach up and push. Walk it through that way.
Chris_94_Sprint_TX
you may be able to idle under the bridge gonna be a tight fit but most likely doable. Article says 4.5 feet clearance underneath. take a measurement of your boat sitting in water from water to tallest point and you will have your answer.
Chris
