Good deal on a boat?
Status
Not open for further replies.
pred8tr
Re: Good deal on a boat?
I agree... I would look into it more...ABout the mercruiser comparison..your basically right, I have twin 350's in my boat and they are comparable to my Chevy sb 350 in my 69' C-10:cool: As for the paint, get some graffiti removal spray made by goof off.. I accidentally sprayed my hull with spray paint and realized a week later... that stuff took it right off.
Awesome. I will give that a try.
pred8tr
I haven't found the goo-gone graffiti remover yet but I did spend some time with an orbital buffer and rubbing compound on it and after 30 minutes I had to call it quits. No help at all.
A few days ago I scrubbed by hand with rubbing compound and that seemed to work but very slowly.... i.e. 30 minutes to remove the bottom of the "F" in free.
I will keep looking for the googone.
25thmustang
I'm not sure if you mentioned this earlier, but I would check the stringers/transom etc...
My 27' boat held water like yours appears to have done in the past. In this time it was able to freeze/thaw and rot out a stringer and some bulkheads.
If yours check out fine, I say drop a used marine engine in it, an outdrive, and have fun.
commander315
Woops it wasn't googone it was krudcutter. Here it is on amazon:.. http://www.amazon.com/KRUD-KUTTER-GR32-Graffiti-32-Ounce/dp/B000P0KNIEI got in both Lowes and HD and its a lot cheaper in those places. good luck
Status
