93maxum4.3lx
Thread starter- Joined
- Aug 2, 2008
- 34
boat: 93 maxum 18' open bow
motor: 4.3 LX ~ 190 HP
drive: mercruiser alpha 1.81 ratio
current prop: mercruiser "Vengeance" 14x19 SS
holds 30 gallons fuel
with 400lb of people, full gas, and a stingray hydrofoil, 42mph at 5100rpm before i pulled it back, it might have made it to 5200 or 5300.
with 800lb of people, full gas, and the hydrofoil REMOVED, it did 43mph at 5000rpm WOT.
The motor is supposed to be 4600rpm or 4800rpm max, depending on what source you trust.
All speeds GPS.
I would like to keep the hydrofoil off, but I miss the stern lift. The 'foil kept the boat very level while getting on plane; without the foil the bow spends 3-4 seconds in the air before getting on plane. With the foil on, the transition was very smooth and effortless.
I know that smart tabs are the answer; but I fear they will be unsuitable for a recreational boat (people getting in and out of the rear of the boat, hitting them with their knees, trying to climb on them, whatever). I know the 'foil is the wrong solution to the problem but it does seem to work well...
I normally cruise the boat around 3600-4000rpm.
So, to get to the point, I'm looking at a prop that meet the following goals:
1 give me stern lift to help the boat get on plane more quickly and replace the stern lift that the foil gave
2 give some more bite to help get the boat on plane more quickly
3 help keep the boat more level at lower speeds for towed tubes/toys
4 not give up too much top speed (I'd like to stay at/above 40mph)
5 not raise WOT RPM
6 not drop WOT RPM below 4500-4600
I keep coming back to a baypro II, but I am worried that the 18pitch will fail me on goals 4 and 5, and i'm worried that the 20pitch would fail me on goal 6 and possibly harm the holeshot if it's too much pitch for my setup.
any comments are appreciated!
All speeds GPS.
5 not raise WOT RPM
