troutmaster1972
- Aug 24, 2009
- 28
Ok 1980 70 horse Evinrude was bogging and stalling badly on me although top end was great if you could get it there Rebult all 3 carbs per instructions here including soaking with all core plugs out Then did link and sync per OMC manual Timing is dead on,fuel pump is not leaking through pulse hose when you pump bulb Took it out and though improved it was far from perfect Will not idle and stay running under about 1100 RPM or so in gear If you give it throttle slowly it will take off perfect Too fast and it will either bog and die or bog slightly then catch and take off Really dont know what to check next Anybody have any ideas? Just want to get it all right so I can winterize it at this point Thanks in advance
