Go change your old VRO !!!
evin300
Re: Go change your old VRO !!!
VRO is not an accurate name for the newest pumps, as they mix at a staight 50:1 ratio, not "Variable Ratio Oil"
CharlesW
Seahorse:<br />Just realized I need to verify that the later, rebuildable pump will replace the VRO pump on my 1986 40 hp Evinrude. Right now, I don't know what pump is on it. I do know it pumps gas, uses oil, doesn't beep, alarm does work when tested. If it is the original, it seemed like it might be a good idea to replace it this winter. If it is a 4 wire pump, I will probably leave well enough alone.<br /><br />Charles
seahorse5
If your pump had a blue-gray fuel outlet fitting and four wires coming out of it, that is the OMS pump that came out in '92 and it is a good one that was used until the new model came out in '98 or '99. Since '92 they have been called Oil Metering Systems ( OMS pumps)<br /><br />Some folks may say it is a constant ratio but that is not true. It averages about 60:1 depending on your usage, but it idles about 75:1 and runs 50:1 at high speeds.
CharlesW
And again, I thank you.<br /><br />Charles
Kesh
The new pump that was intalled in our engine has the oval stainless steel retainers to hold in place with Torx screws the fuel, pulse, and oil fittings.<br /><br />I'm glad to see that it is comepletely repairable. <br /><br />(but I hope to have a twin outboard boat by the next time the pump needs service!)
