lakelover
- Mar 26, 2003
- 4,386
I thought I would add this to the already excellent info I found here before my first try with Gluvit. A few things I was curious about and figured out myself.
Coverage & working time:
The 1 Qt. size (2 lb.) was more than enough to do all the seams and rivets on a 15' Starcraft runabout. At 72 degrees outside, the pot life was about 55 minutes until it got too thick to spread and started clumping.
Mixing:
I actually only mixed half of it up and I'm glad I did that; I had about an ounce or so left over at the end. To mix half by weight, I put a mixing container on a digital postal scale, then turned it on to zero it. I poured 14.4 oz of the resin into the container; then repeated the process for the hardener (catalyst), pouring 2 oz. in a smaller container (zeroed the same way). Then I mixed & stirred it for 4 minutes per directions.
Working time:
I didn't know how much time I'd have when I started out, so I did all the seams first and then went back and dabbed it on individual rivets. After about 40 minutes I noticed that the thickening rate seemed to quicken. It actually was easier to see it filling in the seams when it got thicker, so I went back over them to use up most of what was left.
Using only half allows for mixing the second half later and putting on a second coat, which Gluvit recommends for "optimum" performance.
To sum it up, my advice is to follow the mixing directions carefully, and work fast!!
Good luck!
Mixing:
Working time:
Good luck!
