GPinFlorida
- Feb 25, 2013
- 3
I bought a 1988 14' MirroCraft Jon boat with a 15HP '85 Evinrude. I love it but it does take on a little water. Have to hit the bilge pump once in a while.
So I've bought the can of gluvit. Looks like there was previously 5200 or caulk on the seams / rivets on the bottom. My plan is a wire brush to remove paint / caulk and then use Gluvit. I put some water in the boat and it seems there is a little that comes out beneath the two bottom "rails" on the bottom of the hull. They're probably not called "rails" but as this is my first boat... I'm still learning. They're the two protective ribs or rails that the bottom of the boat would actually sit on if it were sitting on the ground.
The bench seats in the boat are solid and go across the width of the boat and thus hide any rivets at that spot for the bottom rails.
Any ideas on getting the rivets under the rails covered? My brother thinks we can use the gluvit to completely seal around the rails thus keeping the water out. I don't think gluvit is designed for that. There's probably an 1/8th inch gap at spots between the rail and bottom of boat.
Maybe gluvit on accessible rivets / seams and 5200 around bottom rails? Or just live with it?
Any thoughts? Thanks.
Gp
Gp
