Gluvit - Aluminum Boat
QC
I am doing a quick cleanup and turn of a 14' 1972 Sea Nymph. It leaks slightly and I planned to use Gluvit to seal that before painting. Three questions:
1) Do you apply the Gluvit on the inside? Floor?
2) It is only leaking near the transom, again only slightly, almost a weep. With that noted, I guess I should seal everything below the water line. How much of this stuff do I need?
3) I want to paint the whole boat after. I was going to use some can sprayed primer and Rustoleum or something similar, again from a can. Is this plan compatible with the Gluvit?
Thanks
Re: Gluvit - Aluminum Boat
1) Basically,........ Where Ever it's Convenient........
2) I'd think a Quart would be More than enough..........
3) Ayuh,.....
tashasdaddy
quart would be plenty, goes a long way. it's kinda oozzee, you want it to run into the seams, etc.
QC
Kewl. Thanks guys.
