Glow stick test
Bryce2004
Guys I have a 2007 Mariah 3.0 mercruiser, I have a leak that I just cant locate. I was thinking since I work nights can I purchase 5-10 glow sticks and cut them open and place in 5 gallons of water then dump the solution in my bilge and look for the leaks at night. Would this solution hurt anything or please offer other ideas
Black as
Re: Glow stick test
That's a good one:rolleyes:................................Why not just fill it with water because if its leaking it will have to come out somewhere
Bryce2004
Re: Glow stick test
Black as I do agree with you , but due to my work schedule I'm up at night, I was just thinking the glow in the water would help pinpoint the leak a little better
jerryjerry05
Re: Glow stick test
Is the motor leaking or the boat?
Boat:silicone all fittings on the outside of the boat.I had a boat that the drain for the baitwell was missing silicone on the bottom of the drain.I couldn't see it but it leaked enough water that the pump came on every 5 min.
Motor: put it in the water and look for it.
rickryder
Re: Glow stick test
Do you work 7 nights a week? or do you have a day off? I don't think that stuff will make 5 gallons of water glow if it's diluted....
We need more info on when this water is getting in the boat.....when it sitting in the water,when running? Have you tried running on muffs to see if it's a leak in the motor only? Could be bellows....leaking screws or anything thats thru the hull......
seaboo
Re: Glow stick test
Just a different idea, I know a glowing trail would be easier to spot, but how about pond coloring (they sell the "dye" at Lowes, garden centers ect.). One drop makes like 300 gallons of water a DARK blue....A DARK blue trail should be easy to spot, it is environmentally friendly, and water soluable (although granted, like food color it will take alot of water to get it all gone). Plus it will make garage floor cleanup easier I would assume.
jkust
Re: Glow stick test
We put that in our pond last year and boy does it stain anything it touches. I gotta think you would have some unintended consequences.
