QC
- Mar 22, 2005
- 22,783
I am looking at a possible big project boat. I am fairly serious and have found a home built Glen-L plan, Monaco, that is unfinished and a reasonable deal I think. Anyway, here is a pic of a finished one:
The one I am looking at:
This pic is a few years old, it has been sitting, and the deck veneer has separated from the deck. I would have to refinish the rest of the hull and that would be relatively easy. The deck veneer needs to be completely redone, which leads to my question. Glen-L recommends that the veneer is glued on and then you lay a thin sheet of fiberglass cloth over it and then epoxy over that, finally coat with Varnish. The guy who is selling it says that you should skip the glass and properly finish it for a better shine and that the cloth method makes it look dingy. Frankly skipping the cloth sounds easier and I am not worried about strength. The main deck structure is very stout. Sooooo, what is the right/best method for doing new veneer decks?
If I do this I am going to change the look to something more like the completed one ^^^^ as I do not like the gold . . . Almost all of the pieces are there, including a trailer, engine, trans, mounts and deck fixtures. I am y be biting off a big project, but I think I could make a buck or two and do a great project with my boys. I am not going in with blinders on, but will need some help with the woodworking ideas/methods. Thanks.
