1970 Chieftain V
- Apr 29, 2007
- 159
My project is a 30x18x24 livewell. The actual water capacity is about 35 gallons. I am going to make this with a foam core and fiberglass. My problem: I can only find polystyrene foam locally and I want to use polyester resin. 2 reasons for this, polyester resin is much cheaper than epoxy and available locally, and epoxy would be overkill for this application.
I have not used fiberglass before as I have an aluminum boat. So I have 2 questions:
1. I read on an RC airplane forum about wrapping the foam in masking tape to protect it from the PE resin. Has anyone done this or is it even an option?
2. I don't know how to estimate the amount of resin and glass I would need? i.e how many layers would it require? How many gallons of resin? What should the layup schedule be? (CSM, cloth, CSM, Cloth? or 2 layers of 1708?)
Thank you for taking time to answer a rookie fiberglass guys questions.
