Gimbal Ring Replacement
jaybob275
I have a pre-alpha on a merc 228 and I need to replace the gimbal ring, steering spline, and steering arm due to many objections on the board over safety. Thanks btw, I don't wanna die b/c of stupidity.
But I would like recommendations as to how to do it. I have an engine lift for the boat, and I could pull the motor, to get at the gimbal ring but I hear there is a kit/easier way to do it.
What do you guys think? What's easier or any tips on pulling the motor?
JBI
boatguya1
Re: Gimbal Ring Replacement
For customers I do the access plug kit if the are trying to save money. For my own stuff I pull the motor. Details for the access plug kit are in the manual.
James
HT32BSX115
Yeah....I don't like the idea of drilling holes in the transom mount. I'd pull the engine too...but I have everything to do it too....
krisnowicki
I tried that plug kit and it sucked. I would pull the motor.
krisnowicki
the jr kits might not work with the older alpha style drives...
jaybob275
Mike's Alphas--it's an ebay store, has gimbal rings on the cheap. We paid like 200 for the gimbal ring....so we're going to pull the motor I think, but what about the alignment tool? Is it needed?
jbi
HT32BSX115
Uh. YES. You should always check the alignment after pulling the drive. It's about a 5 min job if everything is correct.
gaznaturel
i already use the kit plug and it took me a day to replacement with seloc manual , alpha one , mercruiser 4.3Lx , the worst was to find 1'' tap for the plug
stonyloam
I didn't want to use the plug kit either, so I JB Welded the aluminum cutouts back in and repainted, worked great, have to look really close to see anything. If anyone is interested, pretty easy, once I figured out how to do it, I can post some pix.
