gimbal cracked safe to repair?
antat
Hello thanks for reading this I am new to owning my own boat and I pick up a boat for a few hundred dollers i have a limited budget so I have a small piece missing where the shift cable comes out. on the outside of the gimbal case is it safe to JB weld or will i take on water? sorry if this sounds like a dumb question. I have replaced the t-stat water circulating pump and have run out of funds so if i can just repair it that would be great but i want it to be safe so if not i will have to save for a used one. thanks
Re: gimbal cracked safe to repair?
A picture would help us know what you are talking about as well as the year, make of the engine and what kind of drive?
antat
It a 1987 mercruiser 3.0 not sure on the rest if you can point me the right direction i can look and find more info on it the serial on the engine is not there but its say .181ci 130hp 3.0 on the tag.
Don S
You need a new (or good used) BELL housing
Ayuh,... My guess is that damage was caused by water intrusion, 'n it Froze, splittin' that piece off...
You need a new housing...
antat
Ok thanks for the help now it's time to find a used one somewhere
stonyloam
Try e-bay. Be careful someone has a flywheel cover listed as a bellhousing, so make sure you get the right thing. Good luck.
P.S. You will want to replace your bellows and maybe the gimbal bearing while you are at it.
