kingsfisherman
Thread starter- Joined
- Feb 22, 2006
- 111
I am installing a new gimbal bearing and have encountered some resistance installing it. I figured it is due to not checking the engine alignment prior to pulling the old gimbal out. I also read in the service manual to "make sure the gimbal bearing is properly aligned" prior to adjusting the engine mounts I assume that's referring to making sure the bearing is seated correctly? Also I'm thinking I will need to adjust my engine alignment and then check the bearing if it's seated properly?
