GETTING WATER TO THE HEAD
dslocum
I HAVE A 1991 JOHNSON 120 HP OUTBOARD, WHICH I JUST REPLACED THE WATER PUMP. I CANNOT GET THE WATER UP TO THE HEAD. WHAT AM I DOING WRONG?
D
DJ
Guest
Re: GETTING WATER TO THE HEAD
daboat,<br /><br />You have two heads. Is only one not getting water?<br /><br />If neither, drop the lower unit again, you did not get the water tube inserted into the powerhead correctly.<br /><br />If only one head is hot, I suspect a thermostat or bypass clog.
rdgallo
If it is peeing a good stream, does that mean the water tube is in ok. I just replaced my water pump to and am just curious.
dslocum
NO HEADS ARE GETTING WATER. IT'S NOT PEEING A GOOD STREAM. DOES THAT MEAN THE WATER PUMP IS BAD?
REELSPORT
Might mean you did not get the tubes inserted into the water pump correctly. If that is the case I hope the tubes are not bent that happened to me once. I was lucky I had a spare lower unit.<br />good luck
seahorse5
like already mentioned, it could be that you missied the water tube when installing the gearcase or the white plastic drive "wedge" for the impeller is missing.
