calincoltsdad
Thread starter- Joined
- Jul 17, 2009
- 33
I checked the impeller in my raw pump, everything looked ok, but I turned it around because I've read where you can actually put it in backwards. Dont know if thats true or not and it didnt look any different either way to tell the truth but I got alot more water flow after that. It took alot more time for the engine to get hot but still got up to 185. Can the engine get that hot just idling in a tub of water, water was staying cool. What about on muffs since you're forcing water into the engine then? Should it do ok in the lake since the boat will be moving and water forced due to motion? Just wanting to be sure before I go out again and try it?
