Getting The Short End!!!!
baitfish
:mad: Hears the deal: I BOUGHT AN OUTBOARD FROM A DEALER ON EBAY.. IN THE ADD IT SAID " GOOD COMPRESION,STARTS RIGHT UP"!! WELL WHEN I GOT IT HOOKED UP IT WOULDN'T START! ONLY BACK FIRES! OUT EXUST! DEALER SAYS:"MY MECHANIC SAYS IT RUNS" HE ALSO TOLD ME TO TAKE THE FLY WHEEL OFF, AND REPLACE (SHEER PIN)?? THIS IS A 1979 55HP. EVINRUDE... AM I WRONG?? TO WANT TO SEND IT BACK?? IF I WANTED TO WORK ON A MOTOR I WOULD HAVE PICKED ONE UP THAT NEEDED WORK?? I BOUGHT THIS ONE BECOUSE SELLER STATED"STARTS RIGHT UP!!! BUT IT WON'T!!! OH YEA IT COST $1300.00 W/SHIPPING!! WHAT WOULD BE THE RIGHT THING TO DO??
D
DJ
Guest
Re: Getting The Short End!!!!
File a formal complaint through e-bay. If he's a frequent seller, he won't want the bad publicity.<br /><br />On the other hand, popping the flywheel for a looksee isn't to hard to do.
bandit
I would not touch the motor. if this becomes a legal problem. you taking the fly wheel off would give the dealer a good excuse to why it is not running right. (example in court)dealer you removed parts and worked on the motor who knows what you messed up. give dealer a good excuse to why its not running right.just my opinion.
12Footer
Caveat Emptor or somethin like that. I hate to hear of people getting the deal like that. It happened to me with an outboard ignition system, in which the trigger and stator were shot. Still haven't tried the CD unit or the coils, but have my doubts they are any good at all.<br /><br />How was your motor shipped? Was it crated, strapped to a pallet, or simply hoisted into the back of a pickup truck?<br /><br />Something may have happened in shipping. Double-check the firing order, to insure that the right plug wire is on the right plug. Look at the plugs, anmd make sure non of them got cracked in shippment.
baitfish
THANKS TO ALL WHO REPLIED! :p IT WAS SHIPPED: STRAPED TO A PALLET., CHECKED THE PLUGS, AFTER TRYING TO START IT THEY WERE WET! CHANGED THEM, MADE NO DIF.?? ALREADY GOT THE FLY WHEEL OFF! DON'T NO WHAT A GOOD ONE LOOKS LIKE,SO I'M GOING TO BUY A NEW ONE & TRY IT!HOPE IT WORKS!!!GOTTA GET FISHIN!! OH YEA, 12 FOOTER...SEMPER-FI!!!
jim dozier
Since the flywheel is off I think the seller was telling you to check to flywheel key to see if it was sheared. Regardless, when you put the flywheel back on torque the nut to the proper specifications or it will shear when you start it up. Since you've gone this far squirt some premix in the carb throats and see if it will fire. Then you can go from there.
