Getting rid of Great Stuff
nimmor
I am replacing the floor and decks in my 1979 Tracker. I have found where a previous owner has used expanding foam in several places on the boat. Has anybody found an easy way to remove this stuff? I have been hacking at it with a knife and chisel but this may take all year.
Pmccraney
Re: Getting rid of Great Stuff
Yep, this ^^^^ ... I just used my regular reciprocating saw and it cut through it like butter. You can feel when the tip hits the hull and so you just back off a bit. You won't cut through unless you really, really force it...
Pry bar works pretty good to dig into to some of the tight corners or lift out big pieces you have cut.... With 2 people, I got all of my foam removed in about 2 hours...
Woodonglass
A regular old Carpenters hand saw works well. Cut into section and then use a pry bar to pop out the sections.
oops!
i prefer a package of matches.....lol
oh.....wait a minit......dont try this at home kids
jigngrub
You can dig it out with a straight claw hammer, sink the claws in and pull it out in chunks... repeat as necessary. this is the way we remove foam blockouts in concrete work on the construction site.
jbcurt00
A blowtorch works wonders... As does Gasoline :eek:
Detcord, TNT, C-4, thermite...but I prefer a Backhoe...Just kidding, well sort of...LOL
Ya'lls need to stop sniffing the resin. It's a RESPIRATOR not a handy containment vessel for HUFFING fumes.... The uncured resin isn't supposed to be applied to the filters prior to putting it on. Nor is advised to be applied after you put the respirator on either.......
Step out of the garage once a day whether you think you need fresh air or not.....
(insert 'crazy eddie' photo of PMC or oops grinding) <<--This photo should be hung near a mirror for reference... When YOU look like this, take the rest of the weekend off & step away from the resin.......
nimmor
Thanks for all the replys. The saws all cut most of the stuff away. I then kind of used the claw hammer ideal but used a small crowbar. I still have foam left to get out but it is going a lot faster now. I have always heard to never use expanding foam in a boat because it will absorb water and now I am a firm believer. While cutting into it water was just running out of it.
chriscraft254
Yes, the foam in a boat can and will absorb and hold water. The trick is don't let the water get into the foam in the first place. I would rather have foam in the boat and deal with a rotten stringer and transom in 20 years or more than have a boat with no foam that can sink like a rock. The foam serves a purpose, mainly for floatation during a sinking/taking on water but also serves other things as well like stability on the hull, vibration dampening etc etc.
Put the foam back in if your doing a rebuild imo. It is also required by law on 20 ft boats or smaller.
By the way, so I don't completely derail. handsaw works great.
Also "great stuff" is not what you want to use. You use 2lbs or 4lb 2 part closed cell foam. It does not absorb water as much as a open cell foam like great stuff. The denser the foam, the more water resistant it is. Good luck
Trooper82
Love the title to this thread, after reading what it was about...Getting rid of "Great Stuff"......it was a chore in my case, but I managed to get tennis elbow and a clean hull.
Edit: Just read CHrisCraft's reply...is "Great Stuff" a brand name?
LilRedNeckGirl
all the jokes on great stuff, but lets not discount the product completely. if used above the water line, in areas that are not subject to ponding water, it is a good cheap addition to any arsonel.
it works great for, sound dampining , structural reinforcment, filling hollow areas not subject to water intrusion, etc.
On the older bigger boats, such as my 1985 wellcraft sportsman 248, there was no flotation foam installed. It relies, from what we can find, on air pockets. So we use the foam on areas that are dry, & above the water line, assuring at least a degree of sealed space for flotation.
Woodonglass
I hate the stuff but... I did see a pretty creative use of it on one of my Wood boat forums. The builder filled thick mil plastic bags with it and then heat sealed the bags shut. He then stuffed the bags under the deck and in the sides of the hull before enclosing it. Thought that was pretty ingenious. Expensive, but ingenious. The pour in stuff is WAY cheaper per cubic foot.
wlg
Swimming pool noodles!
