Getting Lower Unit Dropped - '92 88hp Johnson
cs28461
I am tyring to learn how to do this so that I can change the impeller. Took out the 4 bolt/screws (2 on each side) on the bottom side of the motor. Nothing budging. Is there another screw that I take out? Do I mess with the gearcase trim tab at all and that screw?
crxess
Re: Getting Lower Unit Dropped
Year/make/model
cs28461
Sorry.
1992 88hp Johnson
tashasdaddy
the shift rod connection is back under the bottom carb. there are 2 bolts under the trim tab. disconnect shift rod first. DO NOT turn it.
HybridMX6
What he said ^^^^
bankerjohn
Re: Getting Lower Unit Dropped - '92 88hp Johnson
Looking at the gearcase diagram, it looks like there are more than FOUR bolts to remove. You need to remove the trim tab ... plus there is likely another bolt hidden under the trim tab!
cs28461
Got the bolts out and dropped about an inch. Looked under the bottom carb and could not find where the shift rod attaches. Saw a cotter pin attached to a hortizontal rod and pulled it. Nothing.
tashasdaddy
other end of horizonal rod is connection, have to look from port side to see it. it is there, i have done too many of them.
cs28461
is it a cotter pin that I am looking for?
aclmvh
My manual warns that if there is a hidden bolt under the trim tab that is not removed before all the other bolts, "irreparable damage could be done to the lower gearcase". Make sure you remove the trim tab and remove the bolt under the trim tab first!
mvh
Jax/Fl
bankerjohn
mvh
Jax/Fl
Ahhh ... there is some purpose in the statement ... "if all else fails, read the instructions!"
filth
does a '96 88hp spl require these same steps? i.e. am i looking for a shift rod bolt to disconnect also? If so I am having the same problem.
