npd4432
Thread starter- Joined
- Apr 18, 2006
- 468
Throughout the year I have gotten the hot alarm on my boat about three times. The boat has a temp gauge and is between 160 and 220 when running. It seems when I get the alarm the trim is in the lower to middle range but when I trim the motor up and the bow of the boat goes up the temp on the gauge falls to normal levels. The temp gauge reacts to the position of the trim. It seems as if there is an air pocket near the water pickup causing this. What could be the problem?
The boat is a 2000 four winns horizon 170 with a 2000 Johnson 90 HP.
The motor also has a "wale tale" from the previous owner which I plan to take off to see if that is causing the problem.
