Getting air...
dvan1901
Ok, I've read several things on the Internet and watched some video on google videos and such, but I can't seem to really get the hang of it. It seems like if I do happen to get air it's by accident. My brother in law can do it and tried to explain it, but that was too early in my learning to wakeboard to really get it. Any advice you all can give me and others starting out?
mhunt
Re: Getting air...
start way outside of the wake, slowly start to cut and progressively get faster as you get closer to the wake. doing this keeps the rope tight. hit the wake and try to jump off. you can't help but get air.
deejaycee_2000
Re: Getting air...
did you never use to skateboard as a kid? it is exactly the same, just on water, and you don't fall as hard. .....
dvan1901
Re: Getting air...
Yep, I did. I've tried that a couple times, but I would end up catching an edge. I think my problem is that I'm not keeping my edge through the wake. I think I tend to flatten out into the wake.
Lucrestyle
Re: Getting air...
you need a advice from a certified waterski instructor, so here it is.
Jumping on a wakeboard is all about "pop"
i will start from moving outside the wake.
come out slow riding on your toe side once you are 85% out at a 90 degree angle to the wake start your cut, bend your knee's and put your weight into the turn this will create push and speed.
stay straight with the wake, cutting hard and keeping up speed, head up, arms straights, knee's bent.
as you approach the wake ( the bottom) flatten the board ( ie stop cutting on edge like a ski), you want the board to be flat to generate the most flotation or upward push, as you reach the top of the wake don't jump, the idea is not to jump but to "pop" off the wake, it's not like jumping on a skateboard or snowboard you want to use the water, speed and wake to lift you up. you want to generate body lift so think about lifting your shoulders, head, all body parts...this will create the pop you are looking for.
by jumping off the wake you are pushing downwards on the board, ie squishing the wake and making it hard to get good air, by popping off the wake, ie lifting your whole body up as you ride over the top you will generate lots of lift and pop.
hope this helps, remember to keep your knee's bent, arms straight, head up and lift with those shoulders as you peak on the top of that wake! keep that board flat on the wake.
sabastianunf
Re: Getting air...
I am not sure where everyone else here learned to wakeboard but most anyone will tell you a few key points. First of all it is easier to get air on your heelside rather than your toeside. So if you are regular foot go to the right side of the wake - if you are goofy footed then go out to the left side of the wake. You do not have to go way outside to get big air - in fact I would start by only going 10-15 feet outside the wake. let the boat start to gradually pull you back to the center as you get closer to the wake you want to lean on your edge harder and harder with you leaning as hard as you can just befor and as you hit the wake. The "pop" are looking for comes from the force you build as you lean on your edge - if you flatten out before you hit the wake then you will not get that "pop." You also need to stand tall at the top of the wake so that you DO NOT absorb the "pop" with your knees. Now you are not jumping off the top of the wake just straightening you kness so that they do not absorb the lift from the wake. You may want to go to the forum at www.wakeboarder.com if you want more wakeboard advice.
dvan1901
Re: Getting air...
Thanks for the information guys. I will just have to keep practicing. The only thing I hate about practicing is all the falling and feeling like I'm wasting people time. I guess I'll "practice" when it's just my wife and I.
Liquid_force
Re: Getting air...
just out of curiousity...what boat? motor? board (brand/model/length)? your weight?
dvan1901
Re: Getting air...
1993 Larson All American 190 (19') 205 HP. I'm 190lbs. Like I said earlier, my brother in law can jump wake to wake with my same board, but he's been at it a little longer. I've probably wakeboarded 6 times, total, all this year.
sabastianunf
Re: Getting air...
Just keep riding and you will feel it out. try to find a creek where there is less chop/boats on the water - it will be much easier. Also there is a video series called "the Book" which will give you all the info you need on wakeboarding. There is alot more to it than just getting air. Lots of fudamentals to develop so that you will progress better later on.
Liquid_force
Re: Getting air...
You'll get it.
My wife's been riding for about 3 years now, 8-10 times a summer. She's pretty athletic and is just now getting 1/2 way across the wake.
There's so much timing involved - it just takes repetition. One of these times you'll take off like a bird and you'll wonder why it took so long to figure it out.
We have an '89 19' Sunbird 4.3L.
took me 3-4 seasons to get to this point.
another couple to get here (and high end bindings)
dvan1901
Re: Getting air...
Liquid Force, what length do you have your rope at, roughly. I think mine is about the same. What I did was let some rope out, bring the boat to about the speed that I board at and slowly let the rope out until it got to the otimal wake point.
Liquid_force
Re: Getting air...
I think we keep it at 55'.
Every now and then we'll add a 5' section just to try it out, but always end up back at 55'. Of course the tow point is about 6' in front of the stern - so we're no more than 50' behind the boat.
salty87
Re: Getting air...
nothing beats a real person for instruction. most of the people i've talked to who have paid for lessons have been very happy.
fundamentals are everything. you have probably noticed by now that the right way in wakeboarding is the easy way, it takes less effort or exertion if done correctly. if you've got more than a few bad habits, it will be tough...you'll have to strain to make it, you'll be out of position and catch an edge, your chances of getting hurt increase...
once you get the timing down, you'll be surprised how easy it is. i'll try a quick description:
-start out wide with board completely flat
-gradual edge toward wake, edge increases the closer you get
-max edge at wake, handle in front of you kept low (waist level)
-timing, timing, timing at this point...keep edge, straighten legs (pop), pull the rope into your waist...this will seem to be one motion when you get it right
-keep line low when in the air, waist level still and in close to your hips (letting the handle get out in front of you at this point will pull you over the board and into a painful splash)
-spot landing, bend knees a bit to absorb landing, might have to extend your hands out in front for balance...if you do, keep the line at waist level and reel the handle back in as soon as you can (while standing up)
i always tell people to practice on one side of the wake before charging the whole thing (start between the wakes and pop off 1 wake to the flats on that side of the boat). if you can't nail that, you're going to be taken for a ride trying to cross them both.
good luck!
Re: Getting air...
http://www.youtube.com/profile?user=badognobisc
not trying to brag or anything but I have been riding for 8 years now. This season is the first with no surgeries or braces. (make sure to bend your knees on the landing) but this vid will give you an idea on how agressive my outside cuts are and then body position going into the wake and leaving the wake. keep in mind the music lyrics are kinda "adult" in nature so if it offends turn off your sound and best of luck.
