Re: Gentle removal of gas tank
I am concerned with what I will have to cut out to remove the tank. If a structural piece is sawn out will I have to scab in a replacement?<br /><br />Yes<br /><br /> My tank looks to be foamed in but I only have 3 six inch holes to look through. one is at the vent and fill lines, the other is at the sending unit and lastly the fuel line to the engine.<br /><br />You said in your earlier post you pressurized the tank to get the gas out, did you check for leaks at that time? <br /><br />If I get it out and foam in a replacement with a hatch above it is it still up to U.S.G. code?<br /><br /> Yes, there are thousands of boats with a hatch to get to the gas tank.<br /><br />If there is some structure holding it in, can I scab a piece in with fiberglass?<br /><br />Yes but you are taking on a job that I would hate to have to do, I have not seen the under floor area of your boat, you may be changing the structural integrity of the boat. If there was a box built of plywood around the tank, glassed, then the tank was installed with the foam you may be able to brace off of it. But removing the old foam is a job, period.<br />Personally, I would exhaust all possibilities for a leak before I started cutting.<br />And as LouC stated, this is a dangerous job. I would try to find out where the problem is, even if I had to cut out another inspection area. Safely of course.<br />--------------------
