Generator Blower?
stcohen
Hi,
I have a 1988 Silverton conv. w/ twin gas crusaders and a genset under the rear deck. There doesn't seem to be a seperate blower for the genset, is this normal?
Thank you for any advice!!
Reel Poor
Re: Generator Blower?
If the gen set is in the engine compartment it can share the blower with the engines. Pretty common set up.
arks
My Silverton is exactly like yours, and no, I don't have a separate blower for the genset, which is located between the gas tanks below the center hatch in the cockpit.
Funny, the installation was certified by a Kohler technician but, now that you mention it, sounds like a VERY good idea.
-Yet another thing added to my spring "to-do" list!
180shabah
If it is in "shared airspace" with the main bilge then it does not require it's own blower and your setup is normal. However, if it is in a seperate compartment then it requires seperate ventiliaion.
arks
Well in my case all 3 bilges are all joined by scuppers, and the bulkhead between the engines and generator looks a bit like swiss cheese with a variety of hoses and wires passing thru fairly large holes.
While I think my blower does ventilate everything pretty well, IMO it makes a lot of sense to add another.
180shabah
The opperative word was require. I certainly agree with you and the more is better theory when it comes to ventilation. If I were in your position I would probably add a small secondary blower as well.
