Re: Generator - 1964 Evinrude 40hp 40473S
Most of those 40hp Big Twins didn't have the generator, and you really don't need one, frankly. Unless yours has the electric shifter, the only time the outboard uses the battery is to run the starter. A fully charged battery will start that 40 hp dozens and dozens of times, so there wasn't really a need for a generator.<br /><br />They put them on the electric shift models because the solenoids drew power all the time they were in gear.<br /><br />What I do is charge my starting battery the day before I go out on the water. The deep cycle battery for my trolling motor is on a smart charger all the time it's off the water.<br /><br />So, you may not need a generator at all.
