General Motor Maintenance?
tdhopkin
Hello,
I was wondering what general maintenance I should do to my 1991 30 HP Johnson motor to keep it running in optimal condition. The information model number is J30ELEIC.
I just want to be cautious with it, because as the old saying goes: An ounce of prevention is worth a pound of cure.
Thanks for any tips and suggestions!!
BonairII
Re: General Motor Maintenance?
Check your lower unit oil every 10 hours of use(IMO)
Check your plugs regularly(check condition of plugs for signs of running rich/lean/detonation etc)
Use a quality 2 stroke oil
Run your motor within the proper RPM range (prop your motor correctly)
If you have a service manual for your motor(if you don't....GET ONE), it will list scheduled maintenance items that are too numerous to list
tdhopkin
Okay thanks a lot! I do not have a manual at the moment but will definitely pick one up soon. I appreciate your help! :)
