lakelover
- Mar 26, 2003
- 4,390
Mid-December, my generator wouldn't start (10 hp B&S engine). It's 14 years old and probably has less than 50 hours on it. I took it locally to a guy with 25 years small engine experience, and he ended up replacing the fuel filter and carburetor.
Now it starts up pretty good, but really stumbles a lot until it's warmed up. As I adjust the choke, it seems to take several seconds (5-10?) until it smooths out and I can tell whether it either needs more adjusting or it's in the sweet spot. The choke has 4 settings, and it seems to run best, once it warms up, on the first notch-next to the choke "off" position. It's about 30? out today.
When it would start before I took it in, I had to run it on full choke to keep it running. The guy noted on the repair receipt that it "surged" until it warmed up, but to me it seems more like it's stumbling. The spark plug is new.
What would cause that? I was thinking of de-carbing it with Sea Foam because it's probably carboned up from running on full choke previously. Think that might help? I'm going to try it hooked in to the transfer switch this afternoon to see if it runs OK as loads are switched on and off.
