Gen 5 Merc 454 and 502 MPI, VST and Vapor Lock issues...without cool fuel
M Kyle
An old subject, but one I?ve toiled over for a couple of months now. Vapor Lock!! Or is it? I?ve logged hours pouring over forum posts (many on this web-site), visiting with Merc Technicians, performance boat guys and even speaking with Mercury Technical Support on a couple of occasions. Not surprising, some of the ?experts? misdiagnosed my problem, probably because of all the known ?issues? with VST systems from back in the day. Most advised ditching the MPI and VST for a carburetor suggesting ethanol boiling points too low for reliable operations. While research supported some of what they were saying, I also realized there are likely hundreds?thousands of boats still operating successfully with VST systems. BTW, I took fuel samples and didn?t find much (if any) ethanol in my fuel. I performed several component swaps, some that were legitimately questionable. After all my boat is a 1995, so having components operating out of spec wouldn?t be exceptional.
My motor?a GEN 5, 454Mag MPI with a large VST, WITHOUT Cool Fuel. So, the same would likely apply to the bigger brother, 502MPI.
I?m coming from a layman perspective so if I don?t use perfect terminology or if just WRONG on something, please forgive me...and correct me. I?m only trying to provide some solid info for the next unfortunate chap with the same problems.
My big block started and ran flawlessly at the beginning of each new days outing. However, once stopped it heat soaked and developed reliability issues for the remainder of the day. Yes, under the advisement of the Merc Service Bulletin on vapor lock conditions, I ventilated the engine compartment (open hatch), blowers on all the time at idle, idled excessively (relative to previous boats I?ve owned), etc. Nothing seemed to have any affect on the problem. When I described my particular problem to Merc Technical support they relayed that my particular vapor lock condition did not match they?re historical data. My problem was inconsistent and ambient temperatures, water temps, didn?t seem to have any affect on the condition. Merc?s service bulletin described a non start condition after heat soaking. My condition was that my boat would start after heat soak but would only operate 3 to 5 minutes and simply shut down. Restarts were frustrating to say the least. The engine would eventually restart after several attempts requiring sometimes ten minutes. Local Merc mechanics prescribed (without looking I might add) replacing the IAC as the most likely suspect. Because mine is not easily accessible, I replaced it along with the TPS for the same reason.
Over time, the condition worsened (happened more and more often) and I replaced component after component, each time really thinking I had found my smoking gun. Junk in my fuel system, anti siphon valves replaced, fuel lines changed, MAP sensor replaced, fuel/water separators x 4, cap and rotor. All of these things were suspect and easily changed, eliminated as a concern or replaced. I had considered a Marine ? USCG approved electric fuel pump. But I didn?t want the ?key-on? pump. It seemed legit without fuel system molestation, that this boat although new to me, likely operated well the first 20 years of it?s life?so why now?
After all of this, at my end, I finally found a Merc Tech that wasn?t too busy as to look at it. Spring time on the lake is not the time to have boat problems!! Almost immediately the real issue presented itself?the mechanical fuel pump. Merc says this pump produces between 2 and 8 psi on the low side of the system before reaching the VST?where it is boosted to right around 40psi. I?m sure the 2 ? 8 is linear with RPMs. Mine was only producing ? psi at idle and only 2 psi at 1500 RPM.
So why didn?t I look to this component earlier? I?m no mechanic but I do know that mechanical pumps either work or they don?t! Right? Even my car mechanic friends supported my thoughts. NOT SO FAST!! I never thought about it until an obscure forum post from long ago?this mechanical pump, the one in this particular application IS NOT attached to the motor. It?s belt driven and attached to the sea water pump. After years of ignorance, the seals or gaskets?whatever, can allow water to invade the fuel pump?s drive system. What?s more the mechanical fuel pump has a lubricant that is supposed to be changed. Who ever heard of a closed oil system (like a car rear-end) on a fuel pump!? I?m not being critical here?just showing my ignorance.
Now I speculate that MANY people have replaced their older warn out mechanical pumps with new electric ones, figuring the more consistent and likely ?slightly higher? pressures were ?beating? the vapor lock bubble. All along though, their mechanical pump just needed rebuilt.
If I can keep just one guy from having the same frustrations, I feel I?ve done a good thing.
FYI?I buy Valve Tech fuel on the water, supposedly guaranteed to be alcohol free. After fixing my mechanical fuel pump, I?ve never had an issue again. All the performance boat guys critical of my clunky VST?it?s never missed. Even on the hottest days (100plus) and nearly 90deg surface water temp, with the fuel lines too hot to touch?no vapor lock. No boiling fuel in the VST.
alldodge
Looks like you have dealt with this for a while, and good write up, thanks.
My Formula had the 502 MPI VST setup for years. The motor would only vapor lock (VL) when I used Ethanol fuel. Hot day, start it up and start idling out of a cove we were sitting in, start to throttle up and cough and die. The note with VL is that you crank for a bit and it might cough but not run. After enough time and cranking it would fire up and then I would hammer it to get it going. All go afterwards.
Not going into lengthy issues I went through, and I also replaced my mechanical fuel pump after finding thinned lube in the housing (gas leaking into housing). The thing that stopped my VL issue was to stop using ethanol gas and make sure I cooled it down before shut off. Now that I repowered and replaced the VST with standard cool fuel, there is no issues. The fix was taking the return line which went back to the fuel filter and run it back to the tank.
Still plan to remove the cool fuel and probably go with an Aeromotive or Holley pump
Fun Times
Thank you for sharing what you found with your fuel vapor lock like issues. And yes, a low producing mechanical fuel pump would make sense since certain other engine models tend to be able to alleviate vapor lock symptoms by adding an electric booster fuel pump.
Should you continue to see other vapor lock issues, another trick to consider is try removing the fuel return line going to the water separating fuel filter base assembly and plumb it back into the fuel tank somehow such as the fuel tank fill line for one example.
http://www.cpperformance.com/vsearch...earchTerm=fuel fill retu
Or, http://www.ebay.com/itm/Moeller-Mari...p2047675.l2557
Keeping the filter inside the VST tank helps a little too.
alldodge
Here is a layout for cool fuel but VST is the same type connections
fetch
M Kyle
Thanks for the feed back guys. AllDodge, I will likely have to consider the re-route as you provided in the schematic if problem arises again. My only issue is that my Advantage Victory 27 has two fuel cells, one on each side. I have to constantly consider fuel levels as the boat lists badly if one tank has more fuel than the other...I don't have tabs. I found a dealer in Missouri near St. Louis that has experience with this exact VL problem in this particular boat/fuel cell configuration. While I have visited with him, I would really need to do some research (including folks who contracted his service for this particular problem) before indulging his fairly expensive fix. His solution is to remove the VST completely and routes the fuel back to each cell via a 6 way fuel manifold. How he boosts fuel pressure for MPI...I do not know. Most complaints suggest the true VL issue is occurring after 30 - 40 minutes of idle OR after heat soak while sitting. I really don't think I will need that much idle time. The heat soak issue however, does concern me. Time will tell. Again, I appreciate the feedback.
alldodge
The cool fuel Gen 1 uses the same type high pressure pump as what is inside the VST. So sounds like what the guy is replacing the pump and re-routing lines. Basically this was done to my motor during repower
