Gelcoat coloring agent, compatible with Epoxy?
QC
I have an Evercoat Gelcoat Repair Kit. It has little tubes of coloring agent included. Can I use that coloring agent with Pettit EASYPOXY polyurethane? Do they like each other?
Re: Gelcoat coloring agent, compatible with Epoxy?
I can't say anything about your Paint,.....
but,...
I have used the Same Tint you have to color Epoxy Resin......
And,....
It's still holding up after 5 years.........
stevieray
I don't think so, Kevin.
Those tints are polyester based - made to mix with polyester gel coat resin in the kit.
You can try to mix up a real small batch & if it blends evenly with the paint (no lumps or streaks) & if the paint dries OK, I'd say you'd be in good shape, but I wouldn't guarantee it.
Tail_Gunner
See ondarvr or PM him you will get the right answer.
QC
Looks like I need a tie breaker . . . 8) BTW, I noticed the gel coat stuff is looking a little stiff in the tube now. Last time I used it was 2001 or so . . . :^
Edit: Thanks TG
