Gelcoat and Duratec Clear High Gloss Additive
Bonefishr
I'm a bit confused. I will be spraying a fresh coat of gelcoat with Duratec additive to a hull, below water application. Duratec says that for below water applications you must add a styrene wax. I called Duratec and asked if I could use gelcoat with wax rather than adding the styrene with wax. They said yes. I went to Fiberglass Coatings and bought the Duratec. Fiberglass Coating is very respected in the industry. The sales rep there told me to not use gelcoat with wax or styrene wax. It would yellow of I did. I don't know who to believe. Has anyone had experience with Duratec? It is my understanding that you must have wax in the final coat for a proper cure.
Georgesalmon
Re: Gelcoat and Duratec Clear High Gloss Additive
You need the wax to seal the air from the surface and get a hard surface. When manufactuers spray the gelcoat in a mold the mold does this for you. The quick answer is that if you want a smooth shiny final surface by the time you do your wet sanding and buffing there won't be any wax left on the surface to worry about. UV rays will yellow the wax left on the surface pretty quickly. As far as I know all surfacing agents have the wax dissolved in styrene so you can't keep from adding a little styrene along with the wax anyway IMHO.
Bonefishr
Please read my question before replying....I am not shooting a mold. I am spraying an exterior hull. I know wax is required for a proper cure on the final coat when strictly gelcoat BUT....I am using Duratec as a 1:1 additive to the gelcoat. Duratec is a different animal. The reason I am usuing Duratec is because it flattens the gelcoat so there is little or no sanding required. Duratec specs are clear that you must add a styrene wax for below waterline applications. I called Duratec and they said I can use Gelcoat with wax instead of adding styrene with wax to gelcoat without wax. Then Fiberglass Cotaing told me that I should not add styrene with wax or use gelcoat with wax. I'd like a reply from a professional boat builder who has experience with applying Duratec below the waterline.
Ayuh,.... This is a Diy site,... Maybe you should call Duratec back, 'n ask 'em again, then do what They say....
Either do as the Manufacturer says, or go it on yer own...
There's No reason to get snotty with other posters,...
It appears to Me, that Georgesalmon answered yer question, from a Diyer's point of view,....
This is an open forum,...
If ya don't like the answers yer gettin',.... Don't Read 'em....
Georgesalmon
Sorry I confused you. I have used all of the Duretek products in my work or at least as free samples during my 39 years working in the fiberglass and aluminum boating industry. From a manufacturers perspective anyway.
You do need to seal the surface from air and can do it several ways, such as: PVA, wax, or heck, scotch tape will work too.
Woodonglass
GS, I Know I caught you Original introduction on the forum but... I think you should either post it again or add a signature line so everyone on the forum will KNOW that you are speaking from Multiple years of Hans On Experience, and not as a Rank Amateur. I really appreciiate your manners here on the forum and regard your posts with High Respect!!!! Thanks for sharing your knowledge!!!
ondarvr
The short answer is, if you are going to sand and buff it, it won?t make much of a difference.
Both opinions have merit. Styrene has terrible UV resistance and turns yellow rather quickly, when more styrene is added to a formula it typically reduces its weathering properties, how much it?s reduced can be in direct relationship to the amount of styrene added. Duratec clear is already high in styrene and MEK (45% or so), will adding 2% more styrene make a noticeable difference?.maybe.
The resin used in Duratec clear is not as inhibited by air as normal polyester, but you still have 50% normal polyester in the mix, so you are trying to overcome this portion of the mix and have it cure. As a backup plan they say to add wax to help reduce any air inhibiting that may take place.
Under cured polyester will turn a milky white when exposed to moisture, this happens in gel coat or resin, depending on the color of the gel coat you may or may not be able to see it. Dark colors show the blushing rather easily, whites may hide it completely. Dark colors may (typically do) turn milky (blush) even when fully cured, this can be an issue with boats left in the water for long periods of time. The same thing can happen to a white, you just can?t see it. Above the waterline there is less of an issue of having the repair turn milky so they say the additional wax isn?t needed.
If the Duratec/gel coat mix cured correctly (temp and catalyst ratio were correct), then even if the surface was slightly under cured from air inhibition, the sanding and buffing process would remove the under cured surface layer. This would eliminate the portion that may turn milky.
The problem is Hawkeye (manufacturer of Duratec) doesn?t know the exact methods or the conditions of how the product will be used, or what it will be used with, so adding wax will help in the curing process with little downside.
My opinion of using Duratec or other thinners for DIY repairs has sort of changed, not because the outcome has changed, only that expectations of the results are different between DIY and the manufacturer.
Any of the thinners, including Duratec, have possibly negative side effects, reduced UV resistance, reduced crack resistance, blister resistance, gloss retention, color change, etc. When these products are added characteristics of the gel coat are changed, most in a negative way, the benefits can be that it sprays and levels better reducing the amount of sanding needed. Duratec may increase the gloss because as you add more resin you reduce the pigment loading, pigments don?t develop a good gloss, resin will, so reducing the amount of pigment in the mix may give a better shine. Reducing the pigment load can also make a color look richer and deeper, sort of like a clear coat, so this may enhance the look too.
The down side is that gel coat relies almost 100% on the pigments for UV resistance, so by reducing the % of pigment you typically reduce the weathering properties. Reducing the % of pigment by even a small amount can also change the color, sometimes a great deal.
When a manufacturer is doing a repair on a brand new boat, the color needs to be exactly the same, plus stay the same over many years of use and exposure to the sun. This can only be accomplished if the gel coat is mixed and used in the same way it was on the hull, this means very little or no thinning, only enough to make the product usable for the repair. Even then many times the repair can be seen after a few years in the sun, add other stuff and the changes are far more likely.
We do testing to ensure the original gel coat and the methods we recommend to repair it will give the best long term results for a manufacturer, at 5 to 10 years down the road the repair needs to still be invisible if possible. People don?t like finding a big repaired area on the hull side of their new boat.
In the DIY arena, plus in repair shops, the very long term results aren?t quite as important as how fast it can be done, or the initial results when you (or the customer) first see it. If after a few years the repair starts to be noticeable the owner may be satisfied with buffing it out to make it look better, or the boat may have already been discarded or sold. The DIY owner or customer already knows there is a big repair and if after a while it becomes more noticeable they frequently accept it as normal and don?t make a big deal out of it, new boat owners tend to come unglued when they find a big repair.
In a complete respray there isn?t really anything to compare it to, so if it changes color you may never notice.
My recommendations are typically aimed at the best long term result, not on how fast or easy it can be done, or the initial look, this is where my opinion is beginning to change. Many DIY?ers frequently want a finished product that looks good and is relatively easy to accomplish, this can trump long term results.
It?s interesting that when it comes to rebuilding the inside of the boat, stringers, floor, transom, the DIY crowd here typically does a much better job than the manufacturer, the attention to detail, products used and thought going into it are at a higher level. Many will only use epoxy because they feel it will do a better job (it may, but the end result is about the same as polyester). The first thing they ask is, ?What are the best products and methods to fix it?. But when it comes to the outside of the boat, an area where the manufacture typically does a much better job (OLD boats frequently look great on the outside and are totally rotten inside), the DIY?er does things that would get an employee fired on the spot.
Good manufacturers have rules in place on how a repair should be done, this includes catalyst % and the amount of patchaid type product used to thin the gel coat. They have tested the methods and only allow it to be done in one way so the results are far more consistent and long lasting. Adding large amounts of anything is not allowed. Some will use a small amount of acetone (2-5%, but most don?t), and surface agent (wax), others only allow a patchaid product made exactly for doing repairs with gel coat, and then as little as possible is added. Very few (none I deal with) use Duratec for repairs or resprays. Not that it doesn?t have a place, just that none use it for this purpose.
Will adding Duratec and other thinners in large amounts make the job easier to do?yes. It?s up to the person doing the job to decide if the possible downside of doing it this way is worth the tradeoff.
Lots of rambling, sorry for that.
Ayuh,... thanks Jody,... Spot on, Great read, as always....
Yacht Dr.
Will adding Duratec and other thinners in large amounts make the job easier to do…yes. It’s up to the person doing the job to decide if the possible downside of doing it this way is worth the tradeoff.
Fixed that post for ya :) ..
I agree with you 100%. Seems like members skim through posts and then reply without any answers at ALL.
Your question was about Duratec right ? .. well here it is ..
50:50 mix is not good unless your trying to blend an old gelcoat surface. That ratio should only be used for your LAST COAT if your trying to repair OLD FADED colors of Gel.
If your mixing more than 20% to reduce your gel .. your boned from the time you start spraying.
Duratec is a good additive for some projects .. Done correctly its possibly going to do the inverse affect of leaving a repair Too Lustery .. too shiny from the main body of the surface.
You Do not need wax in the gel mix .. thats almost second degree Old School. You can use PVA ( first degree ) or Patch Aid in your final coat. You only need a Skin to trap the solvents (styrene) back to your surface gelcoat.
The Gel will cure off without any wax or PVA .. but sometimes not on the surface ..you can acetone wipe the gummy gel off for most small repair that does not have this/these aditives.
Again .. answering YOUR question about Duratec .. I think its a great product for blending OLD gel repairs mixed in STAGED RATIOS .. but for a full spray nope .. .. PVA is your best bet for ANY larger repairs ( shh .. dont tell anyone )
If your looking for a good Add to your gel .. I think the best one is Patch Aid for a "dont have to add wax or PVA" repairs.
Dont USE styrene. .. EVER .. unless you want to get wax off ( very frikin nasty stuff that styrene in a can is ). Do not use it for a reducer for your gel.
Acetone for a reducer .. well depends on how much you need to reduce. Acetone is the Main reduction thinner that We have been using for Years and Years.
MEK thinner - Not the Cat (MEKP) but the solvent .. might be a better sidekick of reducers along with the acetone to help in your spray.
Basically you do want your gel to be thinned out as least as possible. Your Duratec 50:50 is NOT optimal for your base coats of your gel .. It could be used as a blend coat.
I hope you understand.
YD.
ondarvr
Your answer was correct and much shorter than mine, which can be a good thing. He may have misunderstood what you were saying when you refered to the manufacturing process and instead thought that's what you were targeting with the answer.
Yacht Dr.
So you Need to seal the Duratec with other agents then ??? I dont get what your both saying here ..
YD.
Georgesalmon
Thanks for the post YD. According to the Duratec lit their Hi gloss additive has an "air" dry high gloss enamal like finish when mixed 1:1 with gel coat. I'm guessing that that specific material needs no extra wax added. I'm confused as to why their telling the original poster to use wax. Also they suggest MEK for thinning (or duretec thinner of course) and recommend not using acetone. I should also say that most of my experience with Duretec was centered around mold and plug building or gel coat repairs and probably should not have even tried to answer this question.
Yacht Dr.
Na . you were ok mate ..
If your going to use 50:50 with duratec then you would never need MEK or Acetone. That stuff is thin enough to reduce most gels to spray on its own LOL.
I will tell you what though .. if your talking about plug or mold making .. Duratec makes Fantastic products for that ( just not the clear ).
YD.
ondarvr
YD.
If the OP was told by their tech service people to add wax for below the water line applications, then I assume they are correct in recommending it (I didn't call them to ask). Typically this product is not recommended for this type of use though.
I explained why they may say to add wax in my prior post.
Yacht Dr.
I just tried to call them .. but they are closed ( In California closing on eastern time no less lol )
Ill try to get to the bottom of this subject when I talk to there tech support.
YD.
Bonefishr
Thanks for all the great info.
I apologize to Georgesolman, I didn't intend to be rude, just trying to keep on point. My question was specific to Duratec. I'm new here but have spent enough time on other forums to know that they can get way off topic. Like Yacht Dr said... "Seems like members skim through posts and then reply without any answers at ALL."
I own and operate a fly fishing lodge for bonefish in the Bahamas. I run five skiffs and have doing all the repairs on them for ten years but a couple of them are in need of complete renovations, new gel on the top and bottom. The glass work and sanding are done so I'm ready to start shooting some gel, as soon as the weather clears. I don't want to mess it up. My original plan was to spray the outer hull with a couple heavy coats of gel with no wax and then a final coat of 50/50 gel/duratec to seal it up. I'm still torn about wether or not to use the duratec. I may just shoot the final coat with gelcoat with wax. My concern is about applying it below the waterline. My original note to Duratec......
Hello,
I did call and talk to a sales rep but he wasn't sure about my question. Maybe your chemical engineers know the answer.
I'll be applying the Duratec Clear Hi-Gloss gel Coat Additive to the outer hull of a boat.....so it will be below the waterline. The specs say for below waterline application you must add #7 styrene wax. My question is.....Can I mix the Duratec with Gel Coat with wax and skip the styrene wax or.....Do I have to add the Duratec to gel coat without wax and add the styrene wax?
Some chemicals don't mix well. I don't want to screw this up.
Thanks in advance......Bill
His reply........
The 3 options are very simple, 1 (Gel Coat + Duratec + Styrene Wax) 2 (Gel Coat + Duratec) 3 (Gel Coat + Styrene Wax). If you are using a waxed gel coat with Duratec, that is also fine. All of these materials are compatible with gel coat and will act as air inhibitors. I hope this helps
So.....I went to Fiberglass Coatings if FL and picked up a couple gallons of Duratec. The guys a FC are experts, they have hands on knowledge of Duratec and really seem to know what they're talking about. I talked to them about adding the styrene wax additive because I would be applying it below the waterline and they looked at me like I was nuts. They were very clear, they said do not add styrene wax, use the duratec as is, 50/50 with gelcoat.
I have two experts telling me different things...who to believe. I'm afraid to spray it without the wax because Duratec says you need it for below waterline. I wonder why but I don't want to find out what happens if I don't. On the other hand FC says don't use the the wax.
My additional concern with Duratec is the durability of the final finish due to the dilution of the gel. I'd prefer to be dead before the boats require another redo.
Finally, the ONLY reason I'm considering the Duratac is because my rotator cuff has been giving me grief, all the hand sanding of straight gel will kill my shoulder. I was on another forum saying someone could make a million dollars if they could figure a way to spray gelcoat without having to sand it. One of the members suggested Duratec. He said it thins the gel enough so it lays down flat and has a hard high gloss finish, no sanding. These are work boats not show boats. So even if the finish completely perfect I won't mind....just trying to avoid a couple days of sanding.
So...I'm still confused. I'd did get an injection in my shoulder and it's feeling better. Maybe I'll just use straight gel and do a little sanding....can't wait.
ondarvr
Here is the issue with your plan, and it really has nothing to do with adding wax or not.
The first two coats of gel coat will be fairly rough with orange peel, no amount of Duratec in the final layer will overcome this orange peel and give you a smooth surface. You will need to add Duratec to each layer, and it will take several layers to build it up using Duratec because the viscosity will be so low it will sag easily. If it’s smooth you won’t need to sand as much, if at all, but if you haven’t done it before there may be areas that need a little attention after the spraying. A 50:50 blend of Duratec doesn’t hide that well, if you’re using the same color as the boat was before, then this may not matter much. If you try to cover stripes or other colors the poor hide may cause problems.
The wax or no wax is sort of a non issue, add it to the hull portion and don’t use it on the deck. If these are being sprayed white you won’t be able to tell the difference, if there even is one. While the local guys may know a good deal about fiberglass, they didn’t formulate or make the Duratec, they only sell it.
As I said before, on a total re-spray you may never notice if it fades or yellows slightly.
redneckpunk
Perhaps its my "rookie" ignorance, but it sounds to me like both have said gelcoat and Duratec. Did I read that wrong?
~RNP
Yacht Dr.
Im gonna tell ya right now .. gelcoat=sanding+buffing.
Dont kid yourself or others. .. there is NO additive to make Gel spray like Paint.
If you go with Gelcoat there are pros. .. You cant mess up too bad that you cant fix.
If you go Paint .. you have one shot .. possibly two.
Dont mix your gel with 50/50 ever .. You can reduce to help you on a spray .. you can NOT spray gel and buff expecting any kind of finished results. Not alone without sanding.
The ONLY reason for you to mix a 50:50 mix is if you have a surface that is too thin or too hard to match for a repair.
You Never go 50:50 on your few first passes .. You can go 10-15% .. then 20-25% ( on half of your repair ) .. The 50:50 is only across your blend points.
If you dont know what Im saying.. then this post is Not for you.
YD.
Bonefishr
The more I think about it the less I like the duratec for a couple reasons. As others have said here and on another thread, the gelcoat/duratec ratio must be the same for all coats. Shooting a couple coats of straight gel then a final coat with dutatec won't work. Two reason....It won't smooth out the orange peel from the previous coats. Even if the final coat did smooth out the previous coats when I do future repairs and sand through the top layer of duratec I'll have differences in color where the topcoat of duratec was removed. The other reason being the dilution of pigments at 50/50. The boats are white but I've done some extensive fibergass repair. I had to reglass the entire keel front to back to rebuild the material that's been worn off from years of poling in skinny water. So there are large sections where the original gel has been removed. At 50/50 I'm concerned about coverage of those areas. I was considering up to 20% duratec just as a thinner in all coats but I'll probably get stuck sanding anyway. So at this point I'm just going to shoot straight gel. Darn....gotta sand. I'll use the duratec to paint my fish box, lure dip, make some shiney ear rings, wall paint.....Thanks for all the great advice.
