Geeze, it takes a long time...
MTboatguy
To format a 2 Terabyte Hard Drive. Goodness if I knew then what I know now, I would have waited until we were going on vacation! It might be done by time we got back!
:cool:
hungupthespikes
Master Chief Petty Officer
Re: Geeze, it takes a long time...
Duh, :lol: Nice.
Are you going to divide it up, or just run it as one drive?
CharlieB
LOL
Learned that with my 1T primary, so when I installed my 2T as a 2nd, I waited till evening, then went to bed.
MTboatguy
Oh, in reality, I knew it was going to be a long time, I was just moaning a bit last night, what happened is I trashed the MBR on this drive and was working on getting back up and operational. This will the one partition.
bruceb58
I just installed 2 2TB drives in my Synology NAS. Didn't seem that long.
MTboatguy
last one i formated i used the /q command and was done in a few minutes
Didn't work, tried it, the Master Boot Record was destroyed on this drive, so I had to take it all the way back to the beginning and start over, I finally got another drive in the machine and had to pull this one, drop in an enclosure and redo the whole drive, just like we had to do in the old days.
good old days was to fdisk then format/q in dos. zero fill use to be the nightmare but it was the only way to wipe a drive so it couldnt be recovered
MTboatguy
I was ready to put a floppy drive in that I have laying around and booting off the old MS-DOS disks I thought I had(Wife threw them away, I found out!) and play like I was installing windows 3!
i can not remember if i had to format my ssd drive. i know i had to move data and partions before i could do a drive to drive transfer that was a nightmare as i never got a windows disk and i hate to move a partion on a live drive.
MTboatguy
I still had to format them. They were bare drives.
I can't remember the last time I had to format an off the shelf drive. I only had to do this one because I screwed it up.
bruceb58
You may be right. I installed 2 in a Raid configuration. I thought for sure I had to reformat but maybe not.
MTboatguy
Bruce,
Most drives now a days have the MBR and such set up on them, there is no reason to do low level formatting and such on them, normally you just plug them in and go from there.
