Gearcase spagetti seal Q.
Paul Moir
For my '62 28hp, very similair gearcase to 25hp,35hp,40hp of that era.<br />My Seloc manual tells me to lay the spagetti seal into the groove on the cap, pre-gunked with Sealer 1000, and then put a dab of silicone on the ends to seal it against the propshaft seal carrier. I think it's the only time they suggest silicone, and the stuff pictured looks like it might be useful in the bathroom. (Would it kill them to edit a second edition???)<br />My OEM manual tells me to cut the seal 1/32" long at both ends so it butts into the carrier, but does not mention sealer or anything at the ends.<br /><br />Which would you follow? I'm assuming the business with silicone is suggested in reaction to a problem with the OEM ('62) method.<br /><br />Thanks!
OBJ
Re: Gearcase spagetti seal Q.
Paul....follow the OEM manual. Silicone has no place on an outboard where oil or fuel is involved.
Paul Moir
OBJim - I knew the stuff dissolves in gasoline, and I've heard ('round here) that it's useless on an outboard generally. That's pretty much why I asked the question. The OEM way sounds like it won't work, and the Aftermarket way sounds cheezy.<br />Thanks for your response - I'll go the OEM way.
Hooty
The OEM way is the hot ticket. It works.<br /><br />c/6<br />Hooty
oldoutboard
My experience has been that you need to use that sealer (made by 3M) on the spagetti seal and the same sealer on the carrier ends too.
Paul Moir
Ok, I'm convinced. Thanks a million OBJ, Hooty and oldoutboard.<br /><br />PS - Those are some nice looking restorations oldoutboard!
Paul Moir
Gearcase is holding 5psi fine. Thanks!
oldoutboard
Paul,<br /><br />Thanks for the kind words about the web page. If you need anything let me know.
