gearcase sealant
69fastwin
Good evening,
I'm chancing the seals on the gearcase of my 1969 Evinrude fastwin.
It's ok to use the Evinrude 317201 Gasket Sealing Compound instead to 3m 874 ?
thank you
F_R
Honorary Supreme Mariner
You might get away with it, if you do everything just right. Make sure you have a nice square cut on the ends of the spagetti seal. But you should do that anyway.
But the 3m will do a lot better job of tacking the spagetti in place as you assemble it. It is going to try to hop out of the groove if you use the slippery gasket sealing compound. And 3m will be more forgiving of minor defects.
69fastwin
Thank you for the answers.
The problem is that in Italy is not easy to find the 3m 847. I saw on this video https://www.youtube.com/watch?v=Ap0jZ_X7baY that he use this sealant all around the gearcase case. For you the Evinrude 317201 Gasket Sealing Compound can made quite the same job?
Thank you very much for your help
F_R
Well, we didn't know you are in Italy, and really don't know what is available there. The OMC/BRP number for the 847 is 0776964. Again, I don't know if it is available in Italy.
Sure, there are other options. I suggest you ask around locally. As I mentioned, the Gasket Sealant is thin and slippery. See what you can find locally that is sticky enough to hold it in place until assembled. I'll bet a good boat or car mechanic can advise you on that.
69fastwin
Thank you.
This forum is always helpfull.
Unfortunately in Italy the people don't have the passion to save the old motor they just change them.
I will tray to find something on my Evinrude dealer. Thank you again (and sorry for my english)
Emanuele
F_R
Your English is much better than my Italian.
82rude
Permatex aviation gasket sealer.I use it all the time .I use it as a gasket replacement and its never failed me yet.
69fastwin
Today I went to my evinrude dealer. He gave me loctite 5926. For you is good?
Thank you
HighTrim
That Loctite product is essentially silicone. I have heard from guys I trust that they use the Permatex Ultra Black in your situation, and works well. The only issue I have with the Loctite product is it says not to use if it may come into contact with gasoline. As we all know, with a 2 stroke, that is inevitable.
The Permatex aviation gasket sealer is essentially the same as the OMC Gasket Sealing compound, with the built in brush in the lid. Good for sealing gaskets, not something I would use on a gearcase, just my 2 cents.
