Lanavere420
Thread starter- Joined
- Sep 19, 2020
- 1
Hoping someone can give me a quick tip on
removing the Drive shaft from the lower unit, ever done it before?
My motor is a '73 Sears Gamefisher 9.9hp made by Eska, same as Ted Williams brand.A link to a repair manual would be ideal as I'm sure I'll need to replace seals, etc. etc.
The forward & pinion gears are stripped but I have a good replacement set sitting on a parts motor.
Tried swapping lower units first but the parts lower has a bad drive shaft and shift linkage.
I removed the prop & gear assembly, shift linkage and impeller but the bad gears are held in by the driveshaft.
There does not seem to be a pinion nut or retaining clip on the gearbox-end of the shaft, just a splined end.
Under the impeller there is a plastic cap that seals the opening through which the shaft enters the gearbox.
There are notches on a raised collar next to the shaft but I will damage the plastic if I make the wrong move.
Special tool? Brute Force? Hopefully just missing the obvious... but also missing the water!
