gear selecting
crutch2
first of all hi to everyone ok so i just put in a new water pump in my 85 hp red band merc i put it into foward gear dropped leg replaced water pump put back together pumps water great but now does not go into nuetral or reverse just stays in forward gear wot did i do wrong?
CharlieB
Re: gear selecting
You bumped the shift shaft on the lower unit so it is not 'timed' to the rest of the linkage.
Drop the lower again, turn the splined shift shaft to Reverse, you will feel the indentations in the shift cam at Neutral and another at Reverse. Either position will work as long as you have the control handle in the same position.
If using Neutral you will have to reach up and turn the flywheel to get the the LU up again. Be SURE to pull the spark plug wires to make double sure that the motor cannot fire with your hand on the flywheel.
crutch2
Re: gear selecting
thanks for the info charlieb i will dropp again today so hopefully should work i will post results thanks again
