I have a 1985 9.9 hp with a 2.42:1 lower gear. Are there any other gear sets available for this unit. The powerhead was removed and has been outfitted with a 48 volt 4hp 4000 rpm electric motor for reservoir use...hence the need for a better gear ratio. ? Also.. This motor is on a 16' aluminum boat weighing in at about 900 to 1000 lbs with 2 people. Would I be better off with a 4 blade prop due to the weight ?? Any Help would be greatly appreciated. Thanks
