gear ratio on 1997 johnson 150
90srtatos
Re: gear ratio on 1997 johnson 150
it could have just been running 5100 because it was missing but i think i fixed that problem with a power pack this morning but i will let you know for sure by tommorrow what speed and rpms, now that its running right , thanks guys
michligj
definately find out what the recommended WOT rpms are and match your prop accordingly. The motors are designed to operate in that range, and will last longer<br /><br />For my (older) outboard, 5100 is good rpms, but 5100 for yours might be lugging as mentioned above. I guess I failed to take that into consideration during my previous posts
walleyehed
I don't know any outboard that 5100RPM is "Good" for..<br /><br />EDIT: I take that back...I believe some of the Force engines were either 5000 or 5100 max.
90srtatos
well guys the powerpack fixed my miss ,,,,, now motor runs WOT @ 5700and @ 52 mph that is trimmed all the way up ,,,, can i get more speed out of the motor if so what do i need to do? the slippage at that with a 21 pitch prop is like .16 thanks guys for the input
walleyehed
I show about 14.5% slip...<br />If you can use all of the trim, we need to raise the engine one hole and test.<br />I would also give some serious thought to a bit higher quality SS prop.<br />I have run quite a few MWC props, and the last SS I ran showed higher slip than the Raker I'm running at this point. <br />Another thing that may happen is if we run a higher Rake prop, it may lose some drag due to the lifting ability (the MWC prop doesn't have enough lift)and it may surprise you what you gain in RPM and speed.<br />Just to prove a different blade design doesn't always follow the rules, I went from a polished MWC 19 pitch to a OMC Raker in a 20 pitch...I raised one more hole and gained about 250 RPM and almost 6 MPH in speed....don't see many gaining RPM by going up in pitch, but if the prop currently being used doesn't fit the application or need, the right prop can almost make a new boat out of your rig.
90srtatos
now by saying one hole ( im new to this) do you mean at the back at the motor, it has numbered holes 1 thur 6 with a pin thru them is that the holes your talking about . thanks walleyehed
90srtatos
walleyehed i found a 24 raker could i turn it ok
90srtatos
if i raised the motor 1 hole i know now you mean motor mount holes not the ones i mentioned above
sikpnter
Put a 225 etec on that baby that will cure your need for speed! Your going to fry your motor with a 24 pitch.. You have a heavy boat there get ya a 20 pitch raker, your engine will love it....
90srtatos
what speed will your boat run with the 20 on it sikpnter , i can run about 52 i wanna run faster it can be done i have a 21 now and running about 5700 rpms the recomended range for this motor is 4500-5500 rpms i just read it on the net
sikpnter
I'm running 58 mph @ 5800 rpms 55mph with a full tank of gas and a fishing buddy <br />. My boat is only a 18.5 foot fish-ski, I could get alot more speed out of mine if I went to a higher pitched prop but want to keep my rpms at 5800. Your boat is bigger than mine. It is probably rated for a max of 200 or 225 motor right. There are alot of marine mechanics here who fix these things every day who could explain what happens to a motor when it is lugging better than me. I just have been told by my mechanic and the ones here what lugging a motor does to your motor, I've already had to rebuild mine once and it put me out for a year and 3800 bucks so I'm playing it safe.. your not going very fast when your pistons are on your shelf.. Walleye said it that some props dont follow the rules. I think that you cant beat a raker. I'll bet with a raker you'll pick up some speed.
sikpnter
Can someone explain what lugging a motor does to a motor and what coking is.. It will scare ya.. another question for you stratos, Did they ship that powerpack fast?
90srtatos
yes, ordered on 9-24 or 25 and got it the 28th
