Re: gear ratio on 1997 johnson 150
TLL,<br />Glad to hear that your numbers came in line with what I had. I did the math manually and got the same, So I was relly hoping. <br /><br />stratos,<br />We both agree that your numbers must be off by a little bit. But I wouldn't worry about it. It appears if you adjust the numbers slightly you will easily be below 15%, which is where you want to be.
