Gear problems on E-Tec.
deerhound
Engine details are, E50DPLSRC Serial no 05058553. Engine will not engage reverse, further investigation discovered that the shift rod inside the cowl attaches to a small horizontal shaft, at each end of this shaft are nylon bushes, the one on side of engine where cables come in (starboard side) can not come out because of shift quadrant but nylon bush on Port side is lying free on shaft, this is causing lost movement and lots of freeplay, there is nothing on shaft to prevent this bush from coming out, when enough washers were fitted on shaft to prevent it coming out it goes into gear no bother, does this indicate somthing missing or could this be E-Tec problem? many thanks JBD
DHPMARINE
Re: Gear problems on E-Tec.
I'd look up the motor parts pics on the BRP site and see what is missing.My guess is a plastic spacer.It probably broke and fell off.If I read your model number right it's a 2004,so it must have worked until now.If it's old stock,new out of the crate,call Bombardier.No reason you should be needing to add "washers".
DHP
rwise
2004 E- tec isn't that still on warranty? The last add I seen said 3-10 years (3 year with a big screen TV).
deerhound
Many thanks for advise, I can not find exploded view of top of shift shaft, any ideas how to get there? I think contacting dealer may be answer. thank you. JBD
rickdb1boat
convert
