2 big lake trips, no water in gear lube.
Last 2 lake trips, water. Now I'm doing my 3rd gear lube replacement in 3 months.
Last year, I purchased some of the yellow seals for the drain/fill plug. They are plastic or silicon and pliable. Several people raved that they work great, so I bought a bunch of them. Now, I'm getting water in the lube. It seems that as I make the final tighten on the plug, these things pinch and squirm around -- and fail. To top that off, the ones that I have in the garage are 6-7 months old. I've kept them in a zip lock bag. They are no longer pliable -- stiff as a board. Can't use them.
Luckily, I have a few of the standard seals as well. One them is stiff. And one is still pliable -- so I'll be using that one.
Am I the only one having this issue? Is sucks having to toss 1/2 gallon of new lube because the seal failed. I guess that I am looking for some tricks and tips on these seals. And I'll probably go back to using the older standard type seal.
Yellow seal is a Quicksilver 26-830749
