gear lube leaking out small hole in drive
Alumarine
Hard to see in attached photo but where the red circle is there is a small hole and I have gear lube slowly leaking out.<br />I've just changed my impeller and was wondering if it is the oil passage o-ring that is leaking.<br />any help would be appreciated - thanks<br />74 140 mercruiser<br /><br />
bigbrownbuku
Master Chief Petty Officer
Re: gear lube leaking out small hole in drive
its likely the shift shaft seal thats leaking oil thru that hole. its a very simple replacement, requires a tool for removal you might have to rent. hold the shift shaft down while you are removing the seal, sometimes the cam shifts if the shaft is pulled and it can be tricky to replace
74Silverline
Yep, what BenC said. Mine was leaking the same way this spring. New shift shaft seal and she was all good again. I made my own tool. It was pretty easy to replace....<br />74Silverline
Alumarine
BenC, 74Silverline. Thanks for the info.<br />I guess I should have replaced it when I did the impeller.<br />thanks again.
omgitzdave
Is that small hole normal? I have the same hole there, and I just noticed it!
sker crunch
Yep.....It's a water drain.
