Gear Lube inside water pump?
c03camson
I took my lower off to check the impeller because of overheating and it looked like there was gear lube inside the pump area. Would that mean the seal carrier needs to be replaced or some other seal? Thanks
2003 alpha 1 gen2 (0M551478)
c03camson
Re: Gear Lube inside water pump?
Sweet thanks for the quick reply.
