Re: gear lub & water mix ?
thanks for the info. right now i'm ambivilant about whether or not i got a mix(a leak). my lub is yellow too like hunt is saying.(from his statement i do have a leak) i let my drive sit for 4 days. let a little drip out the drain hole for a look see. it was not sepearated, just more yellow than new lub + maybe a little milky, but still slippery. last time i pressure tested it (very recently) it held for 15 min. at 10 psi and vac tested at 5.5 hg for 15 min. this was with drive on. could not get more than 5.5 hg on the vac test. so it is leaking above that. i'm under the understanding that the vac test will leak at 7-8 anyways, but i am a bit low there. i'll let a bit more drip out today as i had'er out yesterday. see if there's any change. boat sure is runnin dandy right now (with a low compression cyl. too. dons is gonna kill me for sayin that, a low cyl and runs dandy in one statement, not likely. 90 psi on #1 a little oil in the hole brings it to 105. that's another issue though for later) so hope i don't have a seal problem. not that it would suprise me if i did though. <br />dons, why do you say i should be useing hiproformance lub? i'm useing the mercrusier premium gear lub per what my dealer says i should be useing. am i usein the wrong lub on my model 1 drive?<br />one more note.
, seems like a slight difference of opinion here. vatter41 says it won't seperate, bondo say it will, eventually, dons says depends on the lub. hunts sounds like it looks like mine and he did have a seal issue. hummm what's a fella supposed to do......i'm a pessimist so i think i need a seal job. but funds are lacking. guess what i'd like to have happen is to use it the rest of the season(another 2.5 months is a long time), and remove the drive for the winter and have it serviced. assumin i get some more funds that is.<br />another question just came to me too. if i did have a leak. am i correct in the assumtion that if i remove the top vent screw that i would have it leak out there more so than usual as there would be more quanitity of fluid in the drive than there is supposed to be? the proper amount of lub + the water. <br />sorry i'm so long winded, just seems that one question leads to another for me.... thankyou for the help folks, jim
