Gear adjustment? Where is my problem? 1998 50 HP Evinrude
Status
Not open for further replies.
TechMouse
I have a 50 HP Evinrude Model E50DTLECA 1998. It has a hard time going into gear. On the shifter it will engage just after the first click on the stick. Enough to jolt the boat. In reverse it will engage after the first click about half throttle. Enouph to really jolt the boat. I did what I could to adjust the cable but I could only get it to shift better into forward or better into reverse. I thought after reading many forum posts and Youtube vid on the topic that I may have some bad gear teeth. After taking the boot off and looking at the teeth they look fine. Reverse, drive shaft and forward gears almost brand new. I could not detect anything wrong with the gear shift housing. What could I be missing. What would make it so I can not get the boat into gear using the leaver. I can do it by hand. What adjustment do I need to make? I still have the entire thing stripped down so if I have missed some thing in the lower unit I can still get to it. Any help as always think you.
Bosunsmate
Re: Gear adjustment? Where is my problem? 1998 50 HP Evinrude
Have you checked your cables are moving right? ie the gear one pulls away fast as the control lever moves from neutral, well before the throttle cable moves, and is it even in both f and R
TechMouse
Yes and I feel that it is working properly. It is only off from shifting correctly in both directions by a small amount. Do you think my cable is going bad, strechred or starting to seize?
Bosunsmate
If its only off by a little amount then they should be ok.
Hows the clutch dog look?
TechMouse
Looks great
TechMouse
It's only off a little in each direction. I can move it into gear by hand the extra little bit but not when using the cable.
Bosunsmate
How about the reverse thrust washer?
Bosunsmate
I dont get this? If it goes almost evenly into F and R by hand then your cables failing
Bosunsmate
or something in the control box
TechMouse
If I could get the cable to pull a little more and push a little more it would work, but the only adjustments I can find is either push or pole but I cant do both.
TechMouse
All washers and bearings look good.
TechMouse
I have oppend the Controle box several times. The only way I see to do what I feel I need to is make the plastic gear ring more ovel. It's not broken though and I don't want to modify a part if it is something that is failing or starting to fail.
Bosunsmate
Starting to sound like your cables are worn.
So it goes in fine by hand but using the controls the cables not pushing far enough, is that correct?
Bosunsmate
I cant find a picture of the control for a 98 50hp. have you a model number?
TechMouse
It's a new boat to me so I don't know a lot of history with it. But I learned a lot taking the boot apart, and noe I know my gears look good. But It's hard to see some thing so close so far away.
TechMouse
Not for the Controle I will see if I can find one. It's fore a pontoon boat.
Bosunsmate
so long as that difference you mention is only slight then it sounds like cables to me but they arent that cheap, so id wait until someone else at least chimes in with their opinion.
TechMouse
Ok, Thank you so much for your information.
Status
